Home > Maintenance & Modifications > interior trim disintegrates
nicolas0505
France
hello
I would like to know if it is normal that my interior in hardura, it is disintegrated? its made me full of broken piece. I hesitate to put carpet or hardura?
Post #884503 10th Feb 2021 5:35pm
Sulisuli
Hi sorry your having problems, is it possible to explain a little more or perhaps include some pictures so people can offer you some advice. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #884559 10th Feb 2021 7:46pm
nicolas0505
France
here are the pictures
Post #885440 14th Feb 2021 10:24am
donmacn
Wow. I don't think I've ever seen similar pictures, where the matting has separated. I wonder if there's something in your local environment chemistry that's causing that?
The wear in your second picture - at the front of the seatbox is very common - that's just peoples' boots and shoes rubbing against it over time. If you replace it, there are various 'corner protectors' you can buy.
In my car, for the seatbox and floor/bulkhead I have the Wright Off-road accoustic matting. It's a very resistant Polyurethane mat.
I haven't got any pictures on this device, but if you look at my rebuild thread you should find some, or just google. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #885456 14th Feb 2021 11:05am
Dinnu
My 1988 90 had hardura in centre part of bulkhead and transmission tunnel. The transmission tunnel started to crack and fall apart after about 10 years. The bulkhead part survived a bit more, but now after 33 years they went all crumbly. Their foam backing however are as good as new.
In their life I used to only wipe them with a moist cloth. Never used any aggressive cleaners. But they had seen quite some sun shine, which I think dried them out. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #885462 14th Feb 2021 11:57am
nicolas0505
France
I hesitate to take the carpet to redo the interior. I saw at exmoor trim.
the best should be that I find the rubber kit is not too expensive
Post #885532 14th Feb 2021 5:57pm
