Home > Puma (Tdci) > error code p037d
nicolas0505
France
error code p037d
hello
Hello
following the intermittent starting problem in another topic. I just had the problem, I disconnected and reconnected the glow plug relay and that gave me the fault code p037d. could it be related to my intermittent starting? Thank you for your answers
Post #884270 9th Feb 2021 9:43pm
dazzling1611
United Kingdom 2011 Defender 90 Puma 2.2 HT Bronze Green
yes it sounds like a glow plug fault, check the feed into the glow plugs from the relay is ok , then check the resistance on each glow plug.
its either a electric issue or faulty glow plugs.
Post #885164 13th Feb 2021 8:58am
dorsetsmith
2.4 puma engine glow plug cct have feed back too the ecm, if the glow plug relay is removed and ecm call for glow plug no feed back will be given and DTC p037d will be logged also blown fuses in this cct will stop relay from closing and DTC p037d will be logged
pos 2012 2.2 engine puma glow plug cct have glow plug ECM
also check resistance on each glow plug. proxy 0.9 ohm each
Post #885172 13th Feb 2021 9:17am
nicolas0505
France
I put another relay twisted a little the legs and for the moment it works
Post #885412 14th Feb 2021 9:08am
