![]() | Home > Puma (Tdci) > Advice needed on replacing windshield |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 648 ![]() ![]() ![]() |
I wouldn’t have any issues in using a non genuine glass, I have often used it and it is correctly stamped with relevant standards and have had no issues with delamination etc (a non genuine, green tinted glass here in uk LR042725 is under £50 new).
Make sure you get the green tint version if yours is anything other than a basic utility model - (after 2012 all vehicles had a green tint as standard) I have reused the original rubber in the past if not too old with no issues. I have fitted one in the past with a Britpart rubber and the joint failed during fitment. It would be preferably to fit a new rubber however as the old rubber may have a “memory” It should only take an hour or two tops to do the job, the defender is very easy to change. Just need to remove A pillar trims, rear view mirror and sun visors and drop the headlining at the front slightly. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3535 ![]() ![]() ![]() |
If you do it yourself, do not use dishwashing soap to ease the rubber. Dishwashing soap promotes corrosion. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
I would go for original rubber and aftermarket glass, checking it meets OEM standards.
I would not reuse the window rubber because of the heat and sun, which hardens and degrades the rubber. Try and get one of the mobile glass fitters to fit it. They make it look easy. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5868 ![]() ![]() |
LR rubber. Don’t try yourself (not as easy as it looks), Pilkington glass only, (especially if heated). Would be my advice.
It is easy. Anyone with a bit of diy skill can do it |
Black Puma Member Since: 31 Jan 2015 Location: Sydney Posts: 221 ![]() ![]() ![]() |
Thank you everyone. Really appreciate the tips and info. I have been struggling with what to do for a couple of weeks now, so a relief to have a easy plan to get hsi done.
Going to go with genuine rubber, and an aftermarket screen. Looking for Pilkington if possible, and green tint. Seeing as going aftermarket. I will have it fitted, the original issue was, that people didn't want to fit the genuine glass. I guess if they made a mistake and cracked, it's an expensive day for the fitter. |
The genuine glass is Pilkington, and for fitting I use a company that fits lorry and coach/bus windscreens. They appear to be the only ones who know how fit an old school screen. They fit them in no time, and they have never broken one on fitting for me, and that must be about 6-8 screens.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2260 ![]() ![]() |
Landy Andy. Could you advise on the company you use to fit the glass, plus where do you source your pilkington tinted heated screens and new rubber.
It would be handy to have these details at hand incase I get a big stone chip or crack in the windscreen. |
Yes mate.
I use these guys. They’ve fitted many for me, at their site and at wherever I’m working. I’ve also given their details to many others I know and have never heard a bad thing about them. They also will “look after you” if they can and reduce your excess if going through insurance depending on the cost to them. Sometimes I’ve got a new screen through insurance for nothing, other times £30. Just depends on costs, and insurance company. They are in Takley, near Stansted airport, so same county as you. ![]() ![]() https://jayandrobswindscreens.co.uk/ |
Thanks Andy, Essex is not that big, and better to travel a few miles to someone who knows what they are doing with an old school windscreen.
