Home > Maintenance & Modifications > Wheel hub question |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2651 |
Does anyone know if there's a easy way to change from a LR 5 bolt hub to a jap 6 bolt hub?
I have done some researching and you can buy them in AUS (hubs that fit LR axles but have a 6 bolt face) but shipping here would be pretty high.. anyone know of anything closer to home? |
7th Feb 2021 1:16pm |
These are the wheels I’m trying to fit...
8th Feb 2021 3:46pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 |
4x4 fabrication have posted some photos to instagram that show method wheels on a Defender... Might be worth contacting them to see if they can provide a solution? Example here https://www.instagram.com/p/CJTzrouMWwC/ > 110 XS Double Cab
8th Feb 2021 5:04pm |
will ask, but I believe they are complete axle swaps...
8th Feb 2021 5:18pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3466 |
Not the most elegant solution, but there should be adaptors. How strong or how safe they are is a question mark.
http://www.botrak.com/c-5-lug-to-6-lug-wheel-spacer-adapter Not sure if you need a new PCD of 139.7. If yes, that would be 12.7mm radially inwards. Do not know if you can fit some studs on the original LR hub at this new PCD.... but you would definitely need spacers to clear the driving member. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
8th Feb 2021 7:45pm |
rakeway advised against spacers,
to me the truck doesn't go over 30 and potters around the farm and local, hardly anything strenuous, I came across the botrak solution but its a minimum order of 200... |
8th Feb 2021 7:49pm |
MOQ of 200
Either they do not want to run smaller batches, or they want you to have 196 of them as spare 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
8th Feb 2021 7:54pm |
