Home > Maintenance & Modifications > DCPU Spare Wheel Carrier
Page 1 of 3 123>
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Maybe just a temporary blip, but nowhere has a spare wheel carrier for a pick up, and any company I have spoken to have no idea when they will start manufacturing them Confused
Post #883688 6th Feb 2021 11:19pm
Avelingporter
My friend has a Safari Equip one on his dcpu. In fact this is his second as he also had one on his old truck. Try them.
Post #883697 7th Feb 2021 7:25am
Are you looking for a DCPU spare wheel carrier as in internal to the tub or just an external spare wheel carrier to be hung off the rear crossmember?
Post #883699 7th Feb 2021 7:28am
Disco_Mikey
Normal pick up Thumbs Up
Post #883762 7th Feb 2021 12:54pm
landy andy
Post #883763 7th Feb 2021 1:00pm
landy andy
Or if you don’t think you Landy is worth it
https://www.4x4overlander.com/product/whee...-tailgate/
Both apparently in stock.
Post #883764 7th Feb 2021 1:01pm
bankz5152
Naka is ridiculous money frankly.
The Saf equipe I had issues with it swinging open after loosening the antiluce connectors
So for more than 75% less than the Naka I fit a side open tailgate with some custom made heavy duty hinges. Spare now sits on the door as per a normal Def.
 Instagram @defender_ventures
Empire Tuning - Agent
Post #883765 7th Feb 2021 1:13pm
So are you looking for this?
Post #883768 7th Feb 2021 1:28pm
Disco_Mikey
Apologies. One that bolts onto the crossmember
Have spoke to Brendan about it Bow down
Post #883815 7th Feb 2021 4:51pm
One of the reasons that these are hard to find is that there are very, very few that are designed to work with a tailgate rather than a rear door. I only know fo two, the Nakatanenga offering, and the Allisport offering, both of which are rather pricey. If you want one that fits to the crossmember and will work without modification with an Ifor Williams canopy, the number drops even further, to zero. Both of the above will foul the rear flap of the canopy and prevent it from opening, although it isn't hard to modify the Allisport one so that it works. My Allisport carrier was let down by the shocking quality of the powder-coat, but to be fair it was an early one when they were still Sonic3D carriers, not Allisport, so the coating may be better now (it could hardly be worse).
It is about time that someone offered a crossmember mounted swing away carrier for pickups that doesnt foul the rear flap, doesn't foul the towing hitch, and doesn't rust. It wouldn't be difficult.
Post #883827 7th Feb 2021 6:08pm
steve E
Wales
Sorry to ask but does Anyone have the plastic spare wheel securing bolt they would like to sell.
I can’t find the part online and my spare sits on the tub floor.
Post #883829 7th Feb 2021 6:13pm
hank
I understand ORE are developing their carrier to suit the DCPU https://www.ore4x4.co.uk/product-page/ore-...rier-black > 110 XS Double Cab
Post #883832 7th Feb 2021 6:30pm
Roy5695
The exact reason I now have the safari equip wheel carrier. Also many holes in the rear tub so I’m now committed.
I did think about having the ifor canopy hinge at the bottom as you lifted it to clear the spare wheel but it seemed like a lot of faff. Although now I’m looking at re coating the carrier (and sliders, also safari equip) as the powder coat has flakes off in many places. Relieving the galv undercoat. So it won’t rust. Just looks Censored . 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #883864 7th Feb 2021 9:47pm
Roy5695
Plastic? Mine secured with a threaded bar attached to the bulkhead. Had a metal disc with foam on it and a wing nut. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #883865 7th Feb 2021 9:48pm
steve E
Wales
Thanks Roy
I have the threaded bolt from the bulkhead but not the fixing bit to hold the spare in place 👍
Post #883876 7th Feb 2021 10:51pm
Page 1 of 3 123>
