![]() | Home > Maintenance & Modifications > Removing dinitrol to paint |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3656 ![]() ![]() ![]() |
spray it or paint it with white spirits, wait about 90 seconds and wipe it off, repeat until removed DEFENDER 90 TDCI XS,
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
Co1 may I ask how long ago your chassis was dinitrolled? Mine was done 3 years ago but needs a refresh I’m sure.
![]() 2008 SVX 90 2000 XS TD5 90 |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 ![]() ![]() ![]() |
I use this stuff to clear off the old wax & then retreat as necessary...it works a treat. https://www.screwfix.com/p/no-nonsense-hea...5ltr/88668 Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3700 ![]() ![]() ![]() |
Just over two years ago. There is nothing major, just a few rust spots showing through that I want to keep on top of. I’ll do it this summer and then probably the whole thing dinitrolled again next summer.
cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 122 ![]() |
Would it make sense to wire brush it, treat the rust with something like Hydrate80 and then Dinitrol- thats what I was thinking for my chassis.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3481 ![]() ![]() ![]() |
I use white spirit to clean the waxes. Lots of rags required, but depending on area.
I use a product called HG Rust Remover to clean the rust. It is a bit slow working, but it removes the rust, not convert it. There are other rust removers, like DrX, that work faster but find them to be more chemically aggressive. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
This stuff is my go-to solution for removing bitumen based sealants including Dinitrol overspray as well as the sticky residue from most self-adhesive items. It is excellent stuff. However, for removing a thick layer of Dinitrol I'd probably gently warm it up with a heat gun and scrape most of the wax off first.
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 496 ![]() ![]() |
I really wouldn't put wet waxes anywhere near a vehicle they just make a snotty mess and hold in moisture until eventually pealing off. Better to prep the surfaces properly, remove any bolt on parts and treat with a proper primer something like Buzzweld Rust Encapsulator and then Chassis in One on top. If you don't want the work of prepping another good product is Lanogaurd which will need reapplying every couple of years but is much more effective than wet waxes.
