![]() | Home > Technical > Indicator stalk |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 ![]() ![]() ![]() |
My indicator stalk is playing up and needs replacing. Does anyone know who manufacturers the stalk for land rover?
Has anyone renewed theirs with an aftermarket product and been satisfied? I have had some poor quality aftermarket parts recently and just want to get a 'fit and forget' stalk from the start. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2256 ![]() ![]() |
Have you read this, https://www.defender2.net/forum/topic74230...indicators as the problem may be the hazard switch not the indicator stalk.
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Have a spare one on the shelf from Lucas. Can have a look for the part number if you wish.
I hadn't seen that post but it is not the fault I am having, I should have mentioned in my original post. Mine is more annoying than an actual fault - the stalk will self cancel as I am making the turn, rather than when straightening the wheel after. |
Thanks There are a couple of Lucas units for sale and that is most likely what I will buy. I just wanted to see if anyone the OE make. |
This is very common, unfortunately. I've seen it on both old and brand new switches and there's no obvious cause. Whilst trying to track this down a few years ago I came across something that suggested that the rotating part of the mechanism could be 'reset' by turning the wheel from lock to lock but I never had any lasting luck with it. My current 110 does it when turning left and I find that if I hold the stalk down past the click whilst turning then it behaves itself for a while but still returns eventually. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Yep, this is the fault. The stalk itself has quite a bit of free play in it aswell. It's one of those annoying niggles. |
Many thanks Blackwolf |
