Home > Puma (Tdci) > Coil-engine immobilizer |
Can it break down?
this a coil ( only if its open cct ) |
2nd Feb 2021 10:21pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17378 |
It's probably the most reliable component in a fairly unreliable immobiliser system.
2nd Feb 2021 11:24pm |
nicolas0505 Member Since: 23 Dec 2020 Location: briançon Posts: 79 |
I was asking because I have intermittent starting problem. when i switch off the ignition and want to start, the engine cranks a little and then stops. if I restart immediately afterwards, it does not even start the engine, but if I switch off the ignition wait a bit ts reviving the engine a bit. I did this several times and after a while I quit. the next day the vehicle restarts normally.it works for a few days and the problem comes back.
3rd Feb 2021 7:48am |
Johan H Member Since: 12 Oct 2017 Location: Helsingfors Posts: 36 |
If I understand correctly from your description, I had a similar problem.
When I turned the key the car started, but stopped after a few seconds. I must have tried starting the car for 30 mins, and always the same result. In the end my wife gave it a try, and she noticed that if she let go of the key very slowly and gently the engine kept running. The problem was in the ignition barrel, the contacts needed a cleaning, still use the same part two years later, ie. if you're lucky the problem might not have anything to do with the immobilizer |
3rd Feb 2021 8:15am |
This would not be typical of a faulty coil. |
3rd Feb 2021 8:38am |
The transponder coil creates a magnetic field that that excites a coil with in Rf handset this causes the Rf handset to transit a remobilisation code to the 10AS
Coil is only energised when ignition switch is turned to the ignition position and the engine is immobilised Last edited by dorsetsmith on 3rd Feb 2021 10:26am. Edited 1 time in total |
3rd Feb 2021 10:00am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
2.4 or 2.2 with this problem? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
3rd Feb 2021 10:24am |
the engine is 2.4 and it dates from 2007. I cleaned the 2 contacts the red and green of the ignition switch with contact cleaner the 3rd I could not access
3rd Feb 2021 11:17am |
OK, it could be a faulty link due to the instrument pack soldering failing. The alarm unit is allowing the starter to crank, but the ECU is not receiving the immobiliser signal.
https://www.defender2.net/forum/post814212.html#814212 1988 90 Td5 NAS soft top 2015 D90 XS SW |
3rd Feb 2021 1:35pm |
I had seen the trick of making a bridge between 3 and 4, I have not yet tried.
is this normal if I switch off the ignition, leave the key on it and go out and close the door. and like I go back 10 minutes to see 1 hour later. I put the ignition on and the engine cuts I must unlocked with the plip to restart? |
3rd Feb 2021 3:44pm |
