![]() | Home > In Car Electronics > Rear Permanent and Ignition Lives..... |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2931 ![]() |
Quick one, as i understand there is the permanent purple and then the ignition green/white live to the rear wiper motor, but can I take a feed from each of these into a A/B blue sea fuse board to feed other circuits? Or is there a limit to what these can handle? I have the rear seat heaters, the alpine sub and 2 lazer spots to supply.
Thanks Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
The permanent live to the towing electrics is fused at 20amps, from memory, and the feed to the rear wiper will be a lot less. I can't imagine that either would be up to the job of seat heaters and a sub. It'd be far better to run a dedicated power supply for that kit. Darren
Yea, its was early to be thinking about electrics
![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6640 ![]() ![]() ![]() |
Why bother with the ignition sense, use the rear wiper ignition feed as the trigger.
