Home > In Car Electronics > Dim/dip relays on 300TDi
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
I know that this subject has been covered a lot but can I just replace the pink dim/dip relay YWC 10050 with the later bypass unit YWZ10003 to avoid main switch burning ourt so often? Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #881546 28th Jan 2021 1:18pm
Yes, but that's not really the cause of the switch burning out. Alternatively, just unplug the resistor under the wing to disable the system. Darren
Post #881549 28th Jan 2021 1:34pm
jeffersj
Thanks LRA, i think water had got at the relay probably shorting it. if I just unplug the relay are the loose wires/plug OK just left? Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #881556 28th Jan 2021 2:04pm
rallysteve
The headlights won't function correctly if you unplug the pink relay, you would need the bypass unit (or a wire with two spade terminals). You can however just unplug the resistor on the inner wing without any further action.
Post #881557 28th Jan 2021 2:24pm
