Home > Off Topic > Garage floor paint - epoxy resin?
Stacey007
Hello
Looking for a floor paint onto concrete.
The area is 72m square.
I've been told epoxy resin? Is good.
Any views on this or other options? Something I can do myself...rollar it on..
Thanks
Post #881400 27th Jan 2021 7:41pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Resin is good, however it’s not the right time of year to do it unless you can leave it for a fair time under constant temperatures and not drop below 5 as it’ll be a right pita.
I’ve used it on roof’s and then used it on a few workshop floors and it’s a good coating, but slippy when wet.
You can get an additive which creates a non slip surface, but I found that soon disappears once you start wearing the surface down
As with any coating, it requires good preparation and you need to be a on top of the timings when it’s mixed.
Yes, you can roller it on Thumbs Up
Post #881425 27th Jan 2021 8:07pm
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Hi Stacey,
I suggest you use an epoxy primer, flake it and final coat (polyurethane). Makes the floor dust free and I clean mine after major work with degreaser and water. My garage was roughly the same surface area and you will have to move quickly to get it all done in one hit but the result is defintely worth it. IMO.m
Post #881454 27th Jan 2021 9:33pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Over the last few years i've painted a couple of turbine hall floors with a product called Mac Coat. A 2 pack paint designed for concrete floors, not the cheapest but easy to apply. Cut in with a brush then roll it in with a 9" roller. Very hard wearing and easy to mop clean
Post #881479 27th Jan 2021 11:38pm
