Home > Technical > Ashcroft Transmissions - Half Shaft / Flange Failure
Page 2 of 2 <12
90GTR
 2016 Defender 90 V8 Petrol Works V8 Auto Santorini Black
jst wrote:
90GTR, the 'thump on' does it come with a change of direction too each time (ie fwd to reverse?) sounds like bush to me rather than shafts/DMs
When I drove it, reverse and 1st gear no thump or clunk and arguably when 1st to 2nd its not really there (to be fair I was quite gentle / smooth with clutch and shifting). More noticeable in 3rd, 4th, 5th when you got back on power.
Sorry to digress the thread!
Post #880994 26th Jan 2021 10:56am
jst
ok, thats sounds more drivetrain related best start another thread on it, going OT here for OP Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #881039 26th Jan 2021 12:32pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Thanks for all of the responses and good advice Thumbs Up The Ashcroft option is unnecessary for my needs and also rather pricey so in the end I went for the Britpart integrated shafts / flanges but with the improved coating offered by IRB and LOF. This seems to be a good compromise and a search around on here revealed good feedback whilst eliminating another wear point. Luke at LOF was really helpful and even applied a little discount as well getting them in the post for next day delivery so it'll be back up and running before the weekend Very Happy
90GTR - I had started to notice more of a clunk/thud, particularly in the lower gears rather than the higher ones but the 110 has done 140k now so there was always likely to be a bit of play along the driveline. As far as I'm aware, everything is original with the exception of a recon gearbox and the now knackered shafts / flanges. It certainly didn't show signs of imminent failure, it just went bang as I pulled away, almost like when a transfer box jumps out.
JST - unfortunately the oil seals were in there, it was only when looking at the Ashcrofts website the other day I noticed that comment about removing them. The shafts were fitted by a previous owner and I've never had reason to take the axle apart before so was not to know, a shame really as this could possibly have been avoided but at least it broke 400m from home and not miles away! 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #881371 27th Jan 2021 6:52pm
Page 2 of 2 <12
