![]() | Home > Orders 2021MY (L663) > MY21 19" wheel - brake size versus 20"? |
AusL663 Member Since: 25 Jan 2021 Location: Perth Posts: 3 ![]() ![]() |
Hey everyone
I'm going to place an order for a D300 SE shortly and found something in the MY21 technical specs. It shows 19" wheels as running 363/350mm f/r brakes while 20" runs 380/365. From this running 18" tuffants alloys might work if I order factory 19" option wheels? Can anyone confirm if they do change the brake size between 19 and 20 inch wheels, the only reference ive found is from the tech spec at https://media.landrover.com/en/tech-specs, be great it's correct but a huge mistake if I got stuck on 19's! Thanks ![]() Click image to enlarge Last edited by AusL663 on 25th Jan 2021 9:40am. Edited 1 time in total |
Sorry what I was asking is are the brakes the same between 19 and 20 inch rims, the tech spec seems to say they aren't?
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
And what I showed you was the brakes are based on the Engine
Powerful faster engines have the bigger brakes. With those powerful engines and bigger brakes you can not specify the 18" wheel The Powerful Engine can be specified with 19" wheel, 20" or 22" - NO 18" |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
If you spec 22” Wheels then they change the break callipers to 6 piston and smallest wheels size are 20” that can fit.
