![]() | Home > Puma (Tdci) > Transmission mount |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 830 ![]() ![]() ![]() |
Maybe it was one guy having forward planing but cost cutting meant he could not get the bush/rubber etc signed off then when he said ok remove it they also said no money for the redesign so it stays Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3480 ![]() ![]() ![]() |
Well, I used the bracket on the gearbox crossmember to support the gearbox when taking the transfer box out to replace the adaptor shaft (I took the adaptor housing with mount out as well). Now which other manufacturer thinks and makes that for the end user? So has a use, at least for me. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5805 ![]() ![]() |
They must have known how bad they had made the transmission parts on the tdci, so put a bracket in to help you lot.
I like your thinking ![]() ![]() ![]() |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 ![]() ![]() |
Back in 2010 I bought a new Puma which to say the least had too many delivery problems for a new vehicle. On my first journey I heard a loud speed related ticking noise from underneath, so naturally when I pulled up I looked underneath and noticed the "Missing gearbox mount" I thought "those excellent fitters at Solihull " or something similar, and called into the nearest dealer ( I was 100 odd miles from my dealer, at the time) so they could check the noise, and I could get them to order the mounting. Well they said they would order a mounting ( andlike many before I asked the question on this forum)
![]() ![]() Never did get a call back about the missing mounting, and being embarrassed about the ticking noise, I did not go back ! |
