![]() | Home > Technical > Webasto fuel pick-up |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8156 ![]() ![]() ![]() |
Does anyone know if they inline filler pipe pickup works on a HiCapacity where the fuel line angles are a bit different?
Plus does anyone know the ID of a 110 fuel pipe? i see 90 dims are given ,assume 110 is 60mm? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 ![]() ![]() |
Have you got a photo of what the pipe looks like and I'll have a look. Not got mine to hand any more as have fitted it but could look to see if it would fit or not. As long as you have a horizontal piece of pipe running straight into the tank with no further bends you should be fine.wpuld need minimum of about 100mm AFTER the plastic tank tube extension, before the next bend.
cheers i will take a look. Cheers
Webasto evo ordered and am going to use this pickup on the 130. Tank one already in use for Airtop.
So 60mm? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
ok, pipe on 110/130 is 60mm ID.
question is anyone fitted one of these to a pickup/hicap back - is there a long enough straight to fit it in? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Still happy to go measure mine if it helps, i'm going out to it later anyway.
We could measure the minimum distance on mine and you could translate that to your 130 to see. |
