Home > Puma (Tdci) > headlight dipped beam not working after removing dash
Packster82
2013 Defender 110 Puma 2.2 CSW Keswick Green
Hi there,
I recently removed the dash to replace the wiper spindles and having put it all back I’ve realised the dipped beam on the drivers side headlight isn’t working, full beam is fine. Does anyone have any ideas? I’m assuming I’ve damaged/ knocked something whilst messing around with the dash but not sure where to start! If any one has any ideas that would be great. My main thought at the moment is I’ve somehow damaged the main headlight switch and may need to replace it...
Post #879308 18th Jan 2021 12:53pm
Check that the bulb hasn't failed before you get too involved. The failure of the light on one side only is more likely to be a bizarre coincidence than the result of anything under the dash.
Post #879332 18th Jan 2021 3:08pm
Packster82
Thanks Blackwolf, Definitely not a failed bulb as I’ve just changed the headlamps over to LEDs and I have the same problem, the drivers side dipped beam isn’t working but all the modes on both lights are fine. Any other ideas?!
Post #879363 18th Jan 2021 6:28pm
In that case you'll need (or we need, depending on your viewpoint) to take a look at the electrical diagram to see at what point the two circuits separate, sine whatever has gone wrong must be "downstream" of this point.
Post #879375 18th Jan 2021 7:36pm
Packster82
All sorted, turns out it was an issue with the dipped beam fuse terminal. The fuse was fine but managed to replace the metal connector and seemed to have sorted the issue. Thanks for your help on it. Now got a turbo issue so a separate post coming up soon!
Post #879979 21st Jan 2021 5:47pm
