Home > Wheels & Tyres > 285/75’s on 8x16 ET0’s - will I have a problem?
m33ufo
Wales
I’m thinking of fitting 285/75’s, probably STT Pro’s, on 8x16 ET0 Nakatanenga ANR Classics - the car is standard, no lift or suspension mods. Am I likely to hit any problems in terms of tyres rubbing etc in non-extreme use? 110 DCPU
Mark
Post #879112 17th Jan 2021 4:09pm
camelman
I ran that set up on the 110 with no problems.
Post #879116 17th Jan 2021 4:24pm
hank
No rubbing on mine 285/75/16 at ET0 with standard suspension. Moved to ET-30 and had minor scrub to the bottom rear corner of the front arch spats at full lock. > 110 XS Double Cab
Post #879118 17th Jan 2021 4:34pm
camelman
A pic of them fitted.
Post #879119 17th Jan 2021 4:40pm
m33ufo
Wales
Much appreciated gents Thumbs Up 110 DCPU
Mark
Post #879129 17th Jan 2021 5:21pm
Hufflepuff
The issue you might have is if its pushing the boundaries for being out the arch too far.
For reference I'm running 285/75/R16 on my own 90, but on a +10 offset rim, and its pretty close to being inline with the arch, maybe 2-3mm inside, using the BFG KM2 tyre. Maybe you'll get away with it depending on which tyre you select. 2005 Td5 90 XS
1989 V8 110 CSW
Post #879144 17th Jan 2021 5:58pm
m33ufo
Wales
My initial thought was STT Pro’s but haven’t purchased tyres yet so that’s not set in stone. 110 DCPU
Mark
Post #879155 17th Jan 2021 6:29pm
m33ufo
Wales
That looks spot on Thumbs Up 110 DCPU
Mark
Post #879156 17th Jan 2021 6:30pm
hank
Think I am pushing the boundaries but so far have got away with it Whistle
 > 110 XS Double Cab
Post #879323 18th Jan 2021 2:25pm
m33ufo
Wales
Is that with your ET -30’s? 110 DCPU
Mark
Post #879327 18th Jan 2021 2:40pm
hank
Yeah. More like this at ET0
 > 110 XS Double Cab
Post #879341 18th Jan 2021 3:42pm
m33ufo
Wales
Awesome...that’ll do me 👍🏻 110 DCPU
Mark
Post #879350 18th Jan 2021 4:59pm
Hufflepuff
For reference, here is my 285/75/R16 on the original (possibly sagged) suspension, ET10:
It didn't rub on road, but as I also wanted to go off-piste, I added a 2" lift, where there has been no rubbing even at under articulation (although its pretty tight at the back).
 2005 Td5 90 XS
1989 V8 110 CSW
Post #879386 18th Jan 2021 8:11pm
Simboii
Wales 2006 Defender 90 Td5 HT Keswick Green
Re: 285/75’s on 8x16 ET0’s - will I have a problem?
Did you get around to fitting 285’s! I’m thinking of getting a set but dont want the hasstle with rubbing!!
Post #907123 9th Jun 2021 8:33pm
m33ufo
Wales
Played it safe with 265 KW3’s in the end. 110 DCPU
Mark
Post #907130 9th Jun 2021 8:54pm
