![]() | Home > General & Technical (L663) > Stealth mode? |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1115 ![]() ![]() |
Whilst trying to fathom the dim dash display, I found a setting to enable stealth mode when the pivi pro screen is switched off. It’s supposed to dim the switch and steering wheel backlights.
On my Jag, there is a Stealth mode button on the touch screen Additional features, and it immediately blanks the sat nav and turns the rest really low. First question is, other than setting the ‘quick action’ button on the left hand steering wheel switch, to Blank the main screen, how else am I supposed to blank it? If I do set the switch on the steering wheel to blank the pivi pro, it doesn’t dim anything else, so it’s not activated stealth mode. What am I missing here? 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
Ok. Mine is obviously not working correctly. The switch lights are staying full on. 2021 Defender 110 X-Dynamic HSE D300 MHEV
