Home > Maintenance & Modifications > Light switch replacement
Cooperracer05
2003 Defender 110 2.5 TD SW Java Black
2003 TD5
Do I need to take the steering wheel off to replace the light switch (off / side / headlight) or just unscrew the 3 screws in the column housing?
can't find an instruction
Post #878249 13th Jan 2021 3:51pm
bankz5152
Undo the column.
Wheel can stay on.
Theres 4 screws in each corner + 2 on the underside Instagram @defender_ventures
Empire Tuning - Agent
Post #878253 13th Jan 2021 4:15pm
It's a damn sight easier with the steering wheel out of the way, which is easy enough to do. Just remember to only slacken the large nut whilst you wrestle the wheel off, to prevent any wheel/nose interfaces Laughing Darren
Post #878254 13th Jan 2021 4:22pm
Ianh
Or buy the steering wheel removing tool off the net for circa £10.
Post #878256 13th Jan 2021 4:27pm
hank
LandRoverAnorak wrote:
interfaces
Laughing > 110 XS Double Cab
Post #878257 13th Jan 2021 4:31pm
Cooperracer05
thanks all, my wheel is a bit off centre, so I may have a go at getting the steering wheel off
Post #878261 13th Jan 2021 4:48pm
These only work if you have the type of wheel with the daft fake-airbag-growth-like-nodule thing in the middle, if you have the flat type there are no puller holes.
Post #878271 13th Jan 2021 5:11pm
If it is only a little off-centre you'll need to adjust the drag link. Moving the wheel a spline will probab;y make it even more off-centre the other way.
If you do take the wheel off remember it doesn't need to be done up crazy-tight afterwards, and using some anti-seize or copper grease on the taper and splines will make it easier to remove next time.
Post #878272 13th Jan 2021 5:13pm
