Home > Td5 > What’s this please ?
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Hi all, looking into a noise today and seems to be coming from No7 pulley in the picture , is it the water pump ? It’s located above the crankshaft pulley and have a smooth pulley rather than ribbed ,
Thanks in advance
Forgot to say it’s a 2001 td5 90 no air on Fitted
Richard
Post #877544 10th Jan 2021 5:20pm
dorsetsmith
is it the water pump ( no )
Post #877548 10th Jan 2021 5:37pm
htb2
Wales
Idler pulley IIRC, to give more wrap to the alternator pulley.
Post #877550 10th Jan 2021 5:40pm
Gabriel
France
Hello the pulley #7 is the visco-fan pulley.
Post #877552 10th Jan 2021 5:42pm
Daisy90
Viscous fan , that makes sense 👍
I see you can buy a bearing separately,
Anyone done / changed one ?
It just sounds dry and rumbley
Thanks for your time and input
Post #877556 10th Jan 2021 5:47pm
rallysteve
As already said above, no.7 is only a pulley for the fan. I did mine a few years ago. Easy enough to do, just takes a little while depending how much you strip off to do it. I did it with the rad/intercooler removed and the front panel off but you could do it without.
Good guide here:
http://www.discovery2.co.uk/Fan_bearing.html
Post #877558 10th Jan 2021 5:50pm
htb2
Wales
Only an idler pulley on mine as removed fan years ago......
Post #877569 10th Jan 2021 6:18pm
