Home > Maintenance & Modifications > Retro fitting Headlight level |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 333 |
Thread revival alert!
I am finally getting around to fitting these! I got stuck on the headlight bowls and motors. I thought that the hole at the top of the aperture was for the motor arm. However in this position none of the mounting holes align! Turning it around 180° seems to have solved the problem! The wiring is present behind both headlights, but the connector is corroded on the O/S and I will have to replace it. Click image to enlarge Click image to enlarge |
18th Jan 2023 3:00pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Unfortunately if you fit them upside down they'll work in reverse, raising the headlights rather than lowering them, I'm sure incoming traffic won't appreciate that
The motor lives and the bottom and pulls the bottom of the headlights in to dip them rather than pushing the top out 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
19th Jan 2023 8:10am |
Might be good for aircraft spotting though!
That hole at 12O’Clock in the aperture really got me confused!! |
19th Jan 2023 9:51am |
Per perhaps squirrel hunting 2002 90 Td5 Station Wagon
19th Jan 2023 10:28am |
