![]() | Home > Tdi > Heart Broken - New engine required apparently for my 90 |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
bmw m57 engine.....
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3483 ![]() ![]() ![]() |
https://www.ebay.co.uk/itm/254814301812 1951 80" S1 2.0
the gamekeeper Member Since: 01 Jan 2010 Location: Surrey Posts: 97 ![]() ![]() ![]() |
What will be entailed in marrying this up with the transfer box in the Landy |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1467 ![]() ![]() ![]() |
To answer the OP, 300 TDi engines are generally very reliable, probably easiest and cheapest to stick with the same.
Don't know what's wrong with yours or what it will cost to fix. If you need a 'good' used engine to replace it, buying a complete running 300TDi Discovery might take some of the risk away. Buy wisely, good mechanical condition and history, but poor body, and it should be cheap. If it's got MOT, run it for a while to make sure the engine's worth swapping. Sell anything left over for scrap or break it if the axles and gearbox are good. Want to increase the gearing of the 90 to make it quieter at speed? Fit the Discovery transfer box too. Hope you can get sorted. ![]() |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 811 ![]() ![]() |
Did the cambelt snap? Depending on the relationship with your local garage, it might be worth a second opinion from an independent Land Rover specialist. A refurbished Tdi is expensive... second hand ones can be bought in a Discovery as below but buy wisely. Yours may be repairable. Interested to hear the verdict from your mechanic. BORG - Bucks & Oxon 4x4 Response Group ![]() |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 977 ![]() ![]() |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10973 ![]() ![]() |
Mine engine sort of stopped, all info in Millie110 thread, from page 39
![]() As my original engine was in really good condition apart for the head, i'm having it fully rebuilt ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
