![]() | Home > In Car Electronics (L663) > Music from USB |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4260 ![]() ![]() ![]() |
I think the problem comes in when you rip the songs from CD. The track number needs to be at the start of the track name if you want them to play in the album order. Maybe look at the settings of the software you use to rip the cds. 2007 110 TDCi Station Wagon XS
39Steps Member Since: 12 Dec 2020 Location: UK Posts: 48 ![]() |
Thanks for the reply Bluest, I have the track number at the start of the file name but I will try adding it to the track name field and see if that helps.
WMP doesn't seem to have any other options available, well there may be but I cannot find them! Certainly does seem to be a problem many others are experiencing when playing music in a car via USB rather than direct from a phone. Thanks again. |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
With RRS and Evoque there used to be problems using pen drive/ memory sticks directly in the USB slot, mostly anything over 16GB (IIRC, it might have less) couldn’t be used due to limitations in the system also quite a few brands just wouldn’t work properly. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Thanks Tim for the reply I appreciate the info. The USB flashdrive works fine in all respects other than ordering tracks in each album alphabetically rather than the numerical track order.
There is a lot of info on various forums where the issue occurs for many, but I have not found a definitive way to actually sort it. When the dealer reopens this week I will ask them, as I said in my original post there is nothing in the iguide. I am reading about ID tags and have downloaded a suggested tool to assist (MP3tag) but it is a little bit out of my league as to how to use it, as I am not too sure what I need to change. As suggested I am going to add numerical references before the track name and try that, it very cold here today and keep going out to the car to try it is not appealing currently! |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 ![]() ![]() |
There's a feature for the media player to rename tracks automatically. Remember to have had this on some ripping software automatically fetching track names etc. from the internet. This might ruin your efforrt of manually numbering tracks. Haven't tried myself though. Just a guess.
Thanks Sepp for the reply.
An update if anyone is interested or if anyone experiences the same problem - Windows Media Player rips the CD's and adds the track number, beginning 01, to the file name, it does not add the number to the track title. It is the track title which Pivi pro audio uses/ or the Scandisk usb flashdrive (I have no way of currently confirming which) hence the order is alphabetical as there is not numeric reference. Using MP3tag software I added a numeric track number at the beginning of each track title (there are batch options in MP3tag but I didn't use them). A 3 digit number is required so starting 001 etc. Once this is completed the tracks per CD play in the correct order rather than alphabetically. The next thing to do is add additional CD's to the flashdrive and see if I can automatically add the numbers as the CD's are ripped. I will try in WMP, but have also downloaded Mediamonkey which seems to have more options available than WMP. Life would have been easier with a CD player ![]() |
