Home > Technical > New Battery for Remote |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 |
Yeah, but couldn’t be arsed to undo it all so sat and waited in the boot instead😐
6th Jul 2018 10:49am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3431 |
Apologies to resurrect an old thread.
Noticed that when I unlock with the keyfob that I normally use, there are no flash of the amber lights. When I unlock with the spare keyfob, there is one flash of the amber lights. With both keyfobs, when I lock there are 2 (or 3) flashes of the amber lights. Which is correct unlock? and solve by replacing keyfob battery? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
8th Mar 2023 6:56pm |
I think I found the answer on this thread: https://www.defender2.net/forum/topic63068.html
Snippet from https://www.gomog.com/allmorgan/LandRoverSecurityManual.pdf PLIP KEY LOW BATTERY WARNING When the Plip key battery is low, the alarm unit will enter low battery mode. The alarm LED will flash to indicate low battery, and also the hazard lights will not flash when the alarm is disarmed. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
8th Mar 2023 7:39pm |
