Home > Maintenance & Modifications > Fitting rear benchs in a hardtop
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
Has anyone done this? Is it straight forward? Are there legalitys to be aware of? MOT, insurance etc?
Saw this photo the other day on a listing on ebay.
Post #876076 3rd Jan 2021 3:57pm
Dinnu
I am not an expert of UK legislation.... but to my knowledge, it is illegal to have more seats than what is stated in the V5 document.
More over, around 2006, safety boards called for forward (or rearward) facing seats only (although there was something about young children which were permitted on side seats!!!).
Can still install side facing seats on pre Puma Defenders, if it is already classed as M1. I think if you want to change vehicle classification from N1 to M1 now for a pre Puma Defender, then they have to be forward facing seats.
This is what I am aware of, but stand to be corrected. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #876110 3rd Jan 2021 6:33pm
DSC-off
As mentioned above, from 2007 on passenger seats had to be forward facing. Seat belts and their mounting points have for many years have had a requirement to be 'type approved' - designed, tested and certified for the vehicle.
I doubt any insurer would allow those seats to be used to carry passengers, if a full disclosure statement was given to them along the lines of,
"The vehicle has been modified by the addition of non type approved seats and seat belts that do not comply with vehicle construction and use legislation"
Fitting forward facing seats could be just as difficult from an insurance point of view, if the vehicle never had them and wasn't intended to have them. Puma station wagon models (and the 110 USW) have a different body tub with reinforcements for the seat mountings.
Post #876129 3rd Jan 2021 8:47pm
wynn153
Can't see any major problems with it according to this link:
https://www.gov.uk/government/publications...n-the-rear
It Says:
"Although side facing seats, with or without seatbelts, are not illegal, we would not advise that they are used. This is because seatbelts are not designed to be used with such seats. In the event of an accident, seatbelts on these side facing seats may help to prevent the wearer being thrown around the vehicle or from being ejected, but in a frontal crash they can increase injury risk by subjecting vulnerable parts of the body to higher loads than seatbelts used on forward facing seats. You should also bear in mind that child restraints cannot be fitted to side facing seats. In order to fit the required child restraints, you would need to have forward or rearward facing seats with full three-point seatbelts."
just will need to tell your insurer and maybe edit your V5??
It also says:
"It may not be necessary to have your vehicle’s registration details altered, but you should check with the DVLA or your DVLA Local Office.
You should also inform your insurance company of the changes made along with the number of passengers and the manner in which they will be carried."
Don't know if this helps Wink
Post #876241 4th Jan 2021 5:19pm
TamarBlue11
Thanks guys, thats really helpful.
Post #876359 5th Jan 2021 8:04am
JOW240725
I'd imagine it would be an insurance issue, god forbid the worst happen!
Brings back memories of my childhood, my father fitted the back seat of a mini along the side of the 90 hardtop, no belts, used to slide all over the place! Shocked James
Instagram @suffolk_rovers
Post #876385 5th Jan 2021 12:07pm
