Home > Maintenance & Modifications > brighter/additional reverse light & headlight loom
Page 2 of 3 <123>
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I got a pair of LED lamps of eBay for about £25 and have linked one to a switch that I use from the front for when I am reversing and the other is switched from the rear with the engine off when I need a work light.
Cheap, easy to replace and provides plenty of light.
Post #875973 2nd Jan 2021 11:20pm
wynn153 wrote:
If they came on with the reverse light and they weren't approved for reverse lights would it result in an MOT failure?
Just one thing to bear in mind!?
No. I don't think the reversing light is even part of the MOT (it didn't used to be as it's not a legal requirement but things may have changed).
It is illegal to wire a high level "work light" type light into the reversing light, however, and it is in fact illegal to use a work light on the road unless it is used in conjunction with an amber beacon. You are extremely unlikely to be done for doing so however.
Post #875983 3rd Jan 2021 12:24am
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Reversing light is part of the MOT for vehicles built after 2006. Richard
Either a 90, 110 or 130.
Discovery 5
Post #875991 3rd Jan 2021 3:19am
It's pretty unlikely but I do have an isolator switch so that they can be disconnected from the reverse light circuit if required. Darren
Post #876002 3rd Jan 2021 9:55am
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
LandRoverAnorak wrote:
There are so many LED work/flood lights available these days that will do the job that it really comes down what you like the look of. I had a 48w version of the one linked to by wynn153 on the rear of my old 90 and it was superb. On my current 110 I have a couple of the lights linked to by Blackwolf (under £20 for a pair on eBay) and they are also very good.
There are also lots of different ways that they can be wired up. If coupled with an LED bulb in the original reverse light then there's no reason why you couldn't wire an extra light to the same feed as it'll be within the capacity of the wiring. It will only work as a reverse light, though. I wanted to be able to use mine as scene lighting when camping and so they're connected to the second battery and activated by relays. That allows them to be switched on automatically when reversing (and when the side lights are on) or independently when parked.
I have a few different new led lights to try on the rear that will all be switched from the dash and couple switched from the rear also Thumbs Up , I fitted Halford led bulbs in my 65 transit to replace reverse bulbs and it’s amazing how good they are Bow down
Post #876013 3rd Jan 2021 11:13am
Tr90
United Kingdom 2000 Defender 90 Td5 CSW Alveston Red
Switched to be on/ off / on with reversing lamp.
Copied from member on here
Post #876049 3rd Jan 2021 2:15pm
Mo Murphy
Just a note on my experience with Halfords LED bulbs and that is that their longevity is poor and quality no better than very much cheaper ebay offerings.
I use LED stop and tail bulbs in my DRLs.
The first bulbs I bought from ebay lasted about a month before dying within an hour of each other.
The second pair I bought from Halfords, I figured that the higher price would indicate higher quality. However there was a startling similarity between the old ebay and new Halfords both in appearance and weight.
One didn't work out the box, returned and replaced. This pair lasted 6 weeks before starting to flicker continually.
About this time the LED headlamp bulb thread started. While browsing classic car LEDs website I saw they sold stop/tail bulbs for the same price as Halfords (about £8 or so).
I ordered a pair and on arrival they looked slightly different to the Halfords but more noticeably heavier, weighing about twice the weight of the Halfords bulbs.
They've been fitted since then without a single problem.
Halfords sell many good things but LED bulbs are not one of them.
Classic car LEDs on the other hand get my unreserved recommendation.
Hope that saves someone some money.
50 Shades of Pennine Grey
Post #876065 3rd Jan 2021 3:41pm
stew 46
Interesting, the ones I fitted in my transit ( reversing only ) are still working fine but time will tell Neutral
Post #876072 3rd Jan 2021 4:51pm
jst
Cheers Steve, Boomslang arrived today. just waiting on some brighter bulbs now!
Amazon pack of 4 rear LED lights ordered too. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #876928 7th Jan 2021 8:59pm
jst
cheers for all the help.
ordered a pack of 4 LED spotlights as linked in from post - now arrived and awaiting fitting.
thank you TJ101 for the dash switch.
have an order in for an uprated reversing light.
Have some upgraded bulbs now in and Steve loom ready to fit.
Now to find some time! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #878328 13th Jan 2021 9:48pm
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
If you just want a led bulb for your original light speak to Duncan at classic car LED’s, just done all mine. Huge difference.
Post #878499 14th Jan 2021 7:14pm
Timcat
Post #878500 14th Jan 2021 7:16pm
jst
Brilliant thank you, looks impressive, will try one too. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #878509 14th Jan 2021 9:04pm
jst
Ref the other thread on reversing lights, the bulb upgrade timcat suggests is brilliant
https://www.classiccarleds.co.uk/collectio...6-p21w-382 Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #887047 21st Feb 2021 11:33pm
Timcat
They’re impressive aren’t they James, one think I will say is check what type of fittings you have before ordering. Our front indicators were different to the rears & it saves returning them.
Post #887053 22nd Feb 2021 8:26am
Page 2 of 3 <123>
