Home > Maintenance & Modifications > brighter/additional reverse light & headlight loom
Page 1 of 3 123>
jst
I have fitted an LED rear bulb to reversing lamp holder on my 130 but its still not really bright enough.
Any suggestions as to a good quality brighter reversing bulb that someone has tried recently?
Likewise am also considering an external rear worklight to wire as an additional reversing light - if it was LED could it take a feed direct from the existing rev light (to run both together) or would i need to turn that feed into a signal wire to switch a relay for both the original bulb and the additional lamp?
Any suggestions on a discreet surface mount rear light thats functional and doesnt break the bank. i would be looking to mount it up high on the roof of the 130.
Headlight loom upgrades, there are lots out there, the last cheaper ebay one didnt give a flash option when on dipped beam without modification. any suggestions on ones to use with decent core wiring - boomslang? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #875896 2nd Jan 2021 5:08pm
Co1
I’ve got an additional LED work light, can’t recall the brand but it was about £60. it is on a switch on the dash rather than coming in with the reverse light and it makes a huge difference. I haven’t bothered replacing the candle in the standard reverse light as I really done need it!
Post #875911 2nd Jan 2021 6:16pm
Land Reiziger headlight loom. Thumbs Up TheThunder Rolls🇬🇧🇺🇸
Post #875916 2nd Jan 2021 6:31pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Reverse light is 21W, so you should be fine running two led lights off existing wiring.
Ping me your address and I’ll post you an unused boomslang in the post on Wednesday, when I’ve got to post something else.
cheers, Steve
Post #875925 2nd Jan 2021 6:59pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Big recommendation for the scenelite kit.
Discreet fitting with reasonable output
Standard reverse light
Scenelite
 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #875930 2nd Jan 2021 7:14pm
jst
cheers, Steve
Thank you, pm sent Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #875938 2nd Jan 2021 7:47pm
jst
The scene lit is a replacement for std bulb? Where do you get it from?
Edited to add, I see(!) Additional unit, only found light so far, whats in the kit? Whole wiring loom and switch? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #875939 2nd Jan 2021 7:48pm
Bluest
I’ve been thinking about ways to improve my reverse lights too, but without adding any additional lights. I got to looking at a 95mm combined fog and reverse lamps. I could then fit one on each side. I’d then have 2 reverse and 2 fog. Not sure if they would mount within the plinth or how much an improvement that would give, but worth considering.
https://www.carbuilder.com/uk/led-95mm-rev...clear-lens 2007 110 TDCi Station Wagon XS
Post #875940 2nd Jan 2021 7:48pm
jst
S18? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #875943 2nd Jan 2021 7:54pm
DAZ110
James, a few on here have these fitted:
https://www.mudstuff.co.uk/collections/ext...nelite-s17
Post #875948 2nd Jan 2021 8:02pm
Rosco
Light unit only, but for me switched via an illuminated switch fitted on the steering cowl so I know if it's been left on.
Got mine from Ex-MOD at very good price Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
Post #875949 2nd Jan 2021 8:10pm
I have two of these (Amazon link below) mounted at the rear, and one on each side above the second row doors. I can see perfectly in all directions when reversing, and they are also handy if towing a trailer through tight places in the dark. At present all four switch on with a single switch on the dash, but when I get time I will be wiring them on three separate switches (NS/Rear/OS).
They also make great work lights, camp lights, and off-road lights.
All technically illegal for a variety of reasons, but no-one has ever complained and they've been on for years.
https://www.amazon.co.uk/gp/product/B089GV...&psc=1
Similar Chinesium lights are available from ebay.
Post #875951 2nd Jan 2021 8:13pm
wynn153
Re: brighter/additional reverse light & headlight loom
That's what I've done and they are very bright, the worklights were already wired up to a switch on the dash but i put a relay in from a feed from the reverse light. the worklights are a bit old and some of the LEDs don't work so I'm going to replace them with these which are also reverse light approved are officially loads brighter than my old ones.
https://www.ltprtz.co.uk/products/reversin...PZ-RL004-F
Post #875954 2nd Jan 2021 8:37pm
There are so many LED work/flood lights available these days that will do the job that it really comes down what you like the look of. I had a 48w version of the one linked to by wynn153 on the rear of my old 90 and it was superb. On my current 110 I have a couple of the lights linked to by Blackwolf (under £20 for a pair on eBay) and they are also very good.
There are also lots of different ways that they can be wired up. If coupled with an LED bulb in the original reverse light then there's no reason why you couldn't wire an extra light to the same feed as it'll be within the capacity of the wiring. It will only work as a reverse light, though. I wanted to be able to use mine as scene lighting when camping and so they're connected to the second battery and activated by relays. That allows them to be switched on automatically when reversing (and when the side lights are on) or independently when parked. Darren
Post #875960 2nd Jan 2021 9:11pm
wynn153
If they came on with the reverse light and they weren't approved for reverse lights would it result in an MOT failure?
Just one thing to bear in mind!?
Post #875967 2nd Jan 2021 9:34pm
Page 1 of 3 123>
