- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Puma (Tdci) > P193514 Brake Switch/Sensor Signal fault- Help please! |
m3vert
P193514 Brake Switch/Sensor Signal fault- Help please! | |
I have had a few of the P193514 fault codes show up which my local garage thought were a sensor signal fault. They have replaced the 2 switches they thought were the likely cause but alas the fault code keeps re-appearing!
They are at a bit of a loss as to what is the issue and as they closed tonight for New Year break they gave me the landy back. They are going to make some enquiries with people they know who know Defenders better than themselves but I thought I would ask on here if anyone has any idea what could be causing this issue?
Only history I have where I had issues is the handbrake cable got fried when my battery moved as securing mechanism worked loose and battery terminal shorted out. However this was 18 months ago, maybe more. So i doubt that is related?
Any help much appreciated Thanks
30th Dec 2020 7:55pm |
dorsetsmith
abs ? as hand brake and fluid level switch is link to it
have you checked that ecm seeing state from the brake switch i think one switch is norm close for ecm and brake light norm open
if you have open cct wiring for ecm it will not see state change from the switch
30th Dec 2020 8:34pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
