![]() | Home > Technical > Puma 2.2 Starting problems |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3486 ![]() ![]() ![]() |
Hello Cyprus Landy.
Firstly I think it was a good decision to change garage. I cannot understand how an ignition switch would only work on the 2nd try. About the fuel pressure, there is a schrader valve (just so that you understand similare to tyre valve where you inflate it off) on top of one of the fuel lines, in passenger side. Usually there is a green screw on cover. Did the garage read that pressure (fuel pump pressure) or did they read the common rail pressure, perhaps through the diagnostic tool? Here is a good video on how the fuel system works: Would highly recommend getting a cheap obd interface such as ELM237, Bluetooth or Wifi and an app on your phone so can read codes yourself. I had one time a strange case that the 2.2 died and left me stranded. Root cause never understood, but I just cleared the DTC errors and it sprang back into life. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Cyplandy Member Since: 27 Dec 2020 Location: Pissouri Posts: 2 ![]() ![]() ![]() |
They bought in and used LR software, I don't think they know if that is the actual problem. It's pretty frustrating but you have to appreciate that we dont have the mechanical resources here as in the UK. So far I've been slowly replacing parts in order to fix (Iknow this is not the best solution!!) Anyway they are now saying they are going to reload the programme to the ECU which sounds like a logical approach? Those who cannot remember the past are condemned to repeat it!
