Home > General & Technical (L663) > Shift into Neutral without car on
NewDefenderSeattle
United States
When parking my car in the garage I sometimes back up a bit too much so I can't open the tailgate (I have to back into my garage). With my old car I used to shift it into Neutral and just let it roll forward the couple inches that I wanted it to, no need to turn the engine on for that little movement. Is it possible to shift into Neutral without turning the engine on? I tried to look this up in the Owners Manual but no luck.
TL;DR: How do you shift into Neutral without turning the engine on.
Post #874035 21st Dec 2020 7:28pm
Tim in Scotland
Can’t help you with the N situation but if you don’t have the ignition on you also cannot steer the car, the steering wheel simply will not move as the car has electric power assisted steering and it locks if no power. You would need to park with the front wheels fully in straight ahead position to avoid rolling into the wall or garage doors........ Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #874264 22nd Dec 2020 11:39pm
Tennis ball hung from ceiling to touch rear screen, side mirror, etc when in ideal spot is your answer; or even a brick behind rear wheel.
Or read "Chickenhawk" and see how they land helicopters in tight spaces...
Post #874278 23rd Dec 2020 7:48am
DSL
Read Chickenhawk some 30 odd years ago, now that is a blast from the past. Thumbs Up
Post #874279 23rd Dec 2020 7:52am
J77
Hopefully the 90 will fit better Laughing
Post #874358 23rd Dec 2020 2:39pm
DSL
Once, a long time ago in a galaxy far, far away - well late 90s and in my D1 - was helped into a very tight space. We’re talking like 3” - 4” either end. Had no problem getting guided in, the chap who did guiding had even been on a course on parking in small spaces. It’s absurd how tight a space can be. Since then I have lost the skills but at one time I was happily parking in the most crazily tight spaces. Occasionally using the French Method, otherwise known as Le Bump. Thumbs Up
Post #874365 23rd Dec 2020 3:35pm
jonny
Try this - it's how you do it on some of the other models:
This assumes you have battery power. If not, connect up another battery and then follow the procedure.
1. Turn on ignition.
2. Press brake pedal and hold.
3. With brake pedal pressed, pull the + transmission paddle, and hold for more than 10 seconds.
4. The gear selector will rise and you can select neutral.
Post #874374 23rd Dec 2020 4:10pm
J77
Only slight problem, Defender doesn’t have paddles or the rotary knob gear selector.
Post #874385 23rd Dec 2020 4:55pm
DSL
Yet. Whistle
Post #874386 23rd Dec 2020 4:59pm
NewDefenderSeattle
United States
Yeah I have a brick but sometimes I kick it around and or it moves slightly when either cleaning the garage or now getting stuff out of the back.
I kinda tried this. Held the brake and pushed the shifter one notch forward and held. I will have to try 10 seconds or more. Then I wonder if Tim's comment comes in that I won't have steering or if the battery will power that?
Post #874426 23rd Dec 2020 7:57pm
