Home > Maintenance & Modifications > Q about dual beam spot lamps
Jerry
2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Hello
I have just got some WARN SDB-210 dual beam lamps to go onto my roof rack. They have the function to switch beam patterns - from spot to flood etc. Rather than mount the switch provided, can I get my garage to use 2 mud stuff switches and if so which should I buy? I was hoping to mount these in one of their puma mounting panels. Any suggestions would be appreciated. Thanks Jerry
Post #874235 22nd Dec 2020 9:05pm
PaulMc
The Mudstuff (Bearmach) switches are all the same electrically. The only difference is the engraved fronts.
They are a copy of the Land Rover switch YUG000540LNF, which is designed to switch the earth of a relay - search on here, there's lots of info on wiring this switch.
To switch your Warn lamps using two of these switches, you would need two relays -
One with n/o contacts as the 'master' power relay.
And one with c/o contacts to select beam type. Paul.
Post #874469 23rd Dec 2020 10:43pm
Jerry
Perfect thank you
Post #874471 23rd Dec 2020 11:07pm
