Home > In Car Electronics > Dual Battery - Busbar Amps
Joel
United Kingdom 2002 Defender 110 Td5 DCPU Santorini Black
Hi All,
I know this has been done to death, but i had a question about the busbars. I am using 35MM cable, my wiring looks like this
The busbars i ordered are 100A with 5mm studs.
Using a T-Max split charge system with solenoid (middle circle thing).
Are the busbars going to be too small - should i get some 150A / 200A ones? Obviously the battery box is pretty tight, and most of the 150A+ Busbars seem to be massive.
What size bars are everyone else using?
Post #873583 18th Dec 2020 12:44pm
miker
What physical size are the busbars? Current rating is not a uniform thing sadly.
Generally though, I'd have no issues using a 100A rated busbar. The distances are so short and the reality of drawing over 100A for a sutained period are so slim that it'll never be an issue in the real world.
Post #873598 18th Dec 2020 1:40pm
Joel
They are about 100mm long x 10mm wide on the metal strip.
I was more worried about the start draw, but I guess that’s only going to be a lot for a very short period.
Post #873601 18th Dec 2020 1:57pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Hi - I had the same dilemma when building my dual battery system.
High amp rated busbars are super expensive- like more than £50
There are some other options:
1) Buy some copper strips on ebay, drill holes in them and add them to your existing busbar, increasing the cross sectional area of the bars in total and thus its amp carrying capacity
2) Buy this busbar from Mobilecentre (previously of this parish) which is a good quality busbar with cover for reasonable money (no connection to the company, I just have two of these in my set-up)
https://www.ebay.co.uk/itm/372821191566 (they also come in red, just search his shop)
Post #873638 18th Dec 2020 6:36pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Are you sure you need a buss bar? What about battery terminals with more studs (MCool? At least for the main high power (thick) cables. And use some smaller solution for the rest of wires - thinner ones. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #873653 18th Dec 2020 7:43pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
So did I. Left original ground and positive wires and 500A starter fuse untouched.
Post #873678 18th Dec 2020 9:15pm
Joel
Thanks for the advice everyone. I have bought a clamp meter so I will do some testing, but I think I am going to just update the bus bars I have with some copper strip, I have some spare from another project. I will get some better busbars in the new year once funds allow.
Post #873835 20th Dec 2020 11:07am
