Home > Td5 > Fuel filter failure.
Laurie
Twice in six months the plastic drain plug on my fuel filter has failed (broken and dropped off).
Has anyone else had this problem?
Post #87332 2nd Sep 2011 11:47pm
landy andy
I have not, but have read about it in forums. I now carry spare with me just in case.
I don't understand why it breaks though, does it just snap, or does something hit it to break it?
On one of the forums the chap just always puts a bolt into the bottom of the filter and bins the plastic drain.
Andy
Post #87356 3rd Sep 2011 7:07am
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
I've had it happen too so I always carry a couple of spares. I'm always really careful when tightening them now - just tight enough to stop the diesel and no more.
This is one of those daft, fragile, plastic things that totally immobilises you Big Cry It needs someone to produce a nice brass replacement Thumbs Up Dave
Green Goddess - 1998 Defender 110 300tdi
Post #87357 3rd Sep 2011 7:14am
Grockle
Hi Laurie,
Do you think it could be a scrote trying to nick your diesel 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #87358 3rd Sep 2011 7:15am
Laurie
Grockle wrote:
Hi Laurie,
No, unless they're doing it while the fuel pump's switched on Rolling Eyes
It's just a badly designed moulding or inferior plastic.
Last weekend it failed when I was on Salisbury Plain, miles from tarmac.
Bodged it with a seatbelt retaining bolt!
Post #87375 3rd Sep 2011 9:49am
wslr
It's more common over the last year, probably due to the extreme cold we have had making them brittle.
I'm fitting Genuine Part filters now as they come with complete with filter and drainer. Aftermarket ones don't.
Post #87391 3rd Sep 2011 11:08am
Grockle
Laurie wrote:
Grockle wrote:
Hi Laurie,
that's like when you fixed the leak on the USS Gumball using the heel of your shoe Thumbs Up 2.4 90 XS
Post #87420 3rd Sep 2011 2:26pm
Laurie
Grockle wrote:
Laurie wrote:
Grockle wrote:
Hi Laurie,
It was actually the piece of chewing gum stuck to my heel that fixed it. (but don't tell anyone!)
Post #87520 4th Sep 2011 1:21am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
I used a stainless M8 bolt with a rubber washer, works a treat.
Post #87537 4th Sep 2011 8:14am
hopeydaze
United Kingdom 2006 Defender 90 Td5 SW Cairns Blue
Mine broke recently while driving to Scotland from the south. AA fixed it easily with an M8 bolt and the existing rubber washer and its been fine since. Plastic drain plug had split in two. I got the idea its a pretty common problem the AA sees.
Post #87830 5th Sep 2011 9:41pm
