Home > Maintenance & Modifications > Carpet lining the rear of a 90
MarcusM
2007 Defender 90 Td5 HT Keswick Green
Hi All
I have just finished sound deadening and fitting the exmoor trim carpet set to my 90.
Looks great but now I can’t stop looking at the rear load bay...
It’s a van back but has had seats fitted however is currently bare metal.
Not that keen to buy the exmoor trim rear as it’s quite expensive for what looks
like pretty straight lines to fit.
What material/carpet can you buy on a roll that feels the same for interior fitting?
Thanks in advance! Keswick green 2007 Defender 90 TD5
Post #872358 10th Dec 2020 9:08pm
discomog
Try these people, only £4.00 a metre and you can send for samples so may be worth a punt.
https://www.vanliningcarpet.co.uk/product-...zcQAvD_BwE Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #872361 10th Dec 2020 9:16pm
mcma1
Post #872373 10th Dec 2020 10:29pm
AT1963
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
I just have rubber in the back as it absorbs sound and makes loading area easily to clean.
The other thing is wet...easy to lift rubber to let area dry rather than have area stay wet for a lot longer.
Post #872502 11th Dec 2020 8:19pm
MarcusM
Thanks for the replies guys - will check the links out
Agree I’d like to rubber mat the floor but carpet the sides for passengers in the back ideally Keswick green 2007 Defender 90 TD5
Post #872514 11th Dec 2020 9:13pm
