![]() | Home > General & Technical (L663) > Battery problems |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Mine was also delivered in June and so far the only battery warning I’ve had is to start the engine or the radio would switch off in 3 minutes. have you raised the issue with Land Rover Assistance (sometimes a better option than going to the dealer!). Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
orled Member Since: 02 May 2013 Location: NWest Posts: 18 ![]() |
Thanks got that. Will run vehicle few more days whilst measuring voltage then contact them.
Would be interesting if you try same on the Remote App just in case it’s a software issue |
Just done it and no problem from the app other than I got a brief time out message but the us usual and I get the same when I use the remote start. It won’t help that I’ve just come home from town, 16 miles away so the battery will have had a charge , I’ll try again tomorrow morning after it has sat out in the cold overnight. Which version of the app are you using, the old InControl Remote or the later version? There are two in the app stores. When my car was delivered I spent a week with JLR iT trying to get the later app to recognise my log in and it just wouldn’t. They advised to down load the old app that I had been using for the RRS I had between 2015 and 2018, it worked first go and I’ve been using it since. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Have you not got actual build date? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8155 ![]() ![]() ![]() |
Most modern vehicles take approx 20mins to shut down ecus after locking the vehicle. Open a door and it boots everything up again and then another 20mins to close down. L322, 405 were also bad for leaving sat nav routes running when vehicle was turned off, GPS module kept working draining batteries.
Avoid opening closing doors frequently with no startups. A camping trip can be a nightmare. Better to leave doors open if your back and fwd to vehicle alot. All this may be irrelevant in your case but could be of use. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
I’ve tried it this morning after a cool night here and no issues with low battery warnings trying to unlock or lock from the app. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
I tried both new and old Apps as suggested. Same low battery warning despite 12.6v
Happens in all sections of remote app including climate, locking, beep & flash Also tried rebooting PiviPro just in case it had any influence - no benefit Makes me think software issue but will ask dealer tomorrow |
Mark1107 Member Since: 19 Oct 2020 Location: Los Angeles Posts: 74 ![]() ![]() |
For a month driving my Defender everyday I still got that damn low battery warning. I went out two weeks ago and the battery was dead. It was a bitch jump starting the car, which it wouldn’t start. I was able to transfer enough juice to move the freaking seat to even get to the battery. I then drove to dealership and got a new battery for free. Welcome to first year ownership!
![]() Click image to enlarge ![]() Click image to enlarge 2022 Defender Trek Competition 110 collectors edition! 2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold) 2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair 2014 Range Rover L405 Autobiography Full Size Aintree Green 2014 Dodge Viper GTS Stryker Green |
