![]() | Home > Puma (Tdci) > 2.2 Cooling Issues |
I'm not sure that they all do it
![]() One possibility is the viscous fan coupling. If this has failed then the fan will be actively running all of the time and overcool the engine. You'd be able to hear it at idle, though. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
they do cool down when at idle say stood in traffic its s normal witch is a bit annoying in the cold depths of winter . mine takes a while to get warm too
ob1conobe Member Since: 10 Jan 2014 Location: Gloucestershire Posts: 52 ![]() ![]() ![]() |
Apologies - I've realised I have actually posted two threads regarding the same issue - my bad! Anyway, for the purposes of this particular thread I have the update below:
Just found this video on YouTube: Its a ford 2.0 TDCi engine - but the theory of why it's not getting up to temperature properly may still hold true on a 2.2 TDCi. I'm no mechanic but I have not seen this possible resolution anywhere. I'm sure the more mechanically minded may have a view? |
This is a link to other post listing which continues this discussion.
https://www.defender2.net/forum/topic71379.html Apologies again for the duplication! |
