Si_b
Injector code programming | |
Just had to install 2 new injectors into 2.4 puma so could do with re-coding ECU with new details.
I have a new Hawkeye tool which I am lead to believe should be able to do this, it certainly has the options to do this . However it doesn't seem to, you enter the new code, hit ok and it either just sits there or reboots, upon checking the injector codes it has changed nothing and just displays the old details.
Should this be possible or is it a faulty Hawkeye?
thanks
8th Dec 2020 5:34pm |
