![]() | Home > Puma (Tdci) > Changing Radiator & CHT |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 ![]() ![]() ![]() |
Easiest way is to remove the rad shroud, front grill and intercooler. This gives you a clean approach to the radiator and thermostat.
We have done ours now four times, chasin a coolin issue... Can't leave well enough alone |
Kevlar Member Since: 28 Oct 2020 Location: Prague Posts: 78 ![]() ![]() ![]() |
Hi Greyman,
You can remove your CHT with an open ended spanner, I just installed mine with one. Cant remember what size it was though. Its hard to get to but its doable. Unplug it first so the cable is free to spin round. Kev |
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327 ![]() ![]() |
Thanks guys.
Looking forward to cracking on with this to see if it makes a difference but not looking forward to being outside! |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
15mm i think, just get a cheap socket and grind a slot into it.
