Home > Puma (Tdci) > Puma Knocking Noise |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3469 |
You do not mention what kind of work was done to the engine, if at all.
I am no expert on the 2.4s, but could have something fell into the intake, somehow went past the turbo compressor without damaging it, but damaged a valve? Maybe remove the injectors again, turn the engine over to top dead center for each piston just before the power stroke, and do a leak down test? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
4th Dec 2020 7:45pm |
Take it out, whack in an LS...
Click image to enlarge |
4th Dec 2020 7:48pm |
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 269 |
Just to confirm....injectors on this engine can make a knocking type sound, two of mine have done it at different times. However a primary learn has almost eliminated it each time.
It’s interesting that the kill test on No.2 considerably reduces the knock. It could be small end, when no fuel is present and consequently no combustion, no instantaneous load. Just a thought....... 2011 130 Utility Body 2005 110 Van |
4th Dec 2020 11:48pm |
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 92 |
Loose injector, change the copper washers and the screws that hold it!
I think the tightening torque is 6NM and then 180º |
5th Dec 2020 1:00am |
Safarihp Member Since: 14 Feb 2014 Location: Oraldno Posts: 15 |
Thanks for the responses.
This is a new genuine engine. We are now US experts on the Puma or so it seems. We are Very good at installing LS3s wish we could on this truck. https://safarihp.com/project-johnson-defender-110/ We have checked the injectors many times over. New washers and learns each time. We have been running circles on the truck and the knock for sure. Thanks for any advice and please keep any suggestions coming. We really feel that it is fuel related as there is zero metallic particles in the oil x 2 drains. We have also moved the valve train from a runner and installed on the offending motor without any change. Thanks for reading and offering us Yanks a few suggestions. |
7th Dec 2020 4:31pm |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
Some great builds and conversions in your portfolio !
I can’t help much with your knocking but if it is as you suspect fuel related , have you looked at changing the suction control valve or fuel rail sensor ? I don’t believe either would show with a diagnostic scan . Both are known to cause all sorts of issues. If you do replace , only use genuine parts . The others aren’t worth the hassle . Good luck https://www.instagram.com/hustynminepark/ |
7th Dec 2020 11:01pm |
