Home > In Car Electronics (L663) > Update 2 november -> More problems than fixes? |
defender_auug Member Since: 23 Oct 2020 Location: Chicago Posts: 53 |
Just saw it - parked and locked. Will see in the AM
2nd Dec 2020 2:50am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
Will different spec vehicles get different versions of the update?
My car just updated to OS 2.0.5aC6 130's have feeling's as well you know |
4th Dec 2020 2:00pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
Mine updated to 2.06 P1B1C18 yesterday, gives you an Enhanced Hill Hold button on the Quick Menu, you can now say “hey Land Rover” to wake it up and then given it a command to do something but when I told it to “set the wipers to winter park position” I got a reply that it didn’t understand my instruction....... seems it’s only an add on to the useless voice commands already there. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
4th Dec 2020 5:16pm |
W84IT Member Since: 28 Sep 2020 Location: Indio, California Posts: 111 |
I just did the update in mine this morning but I haven't had a chance to play around with it to see what has changed...
Ray 2020.5 Defender 110 P400HSE 2016.5 Range Rover HSE |
4th Dec 2020 8:17pm |
umbertob Member Since: 21 Jun 2020 Location: Altadena, CA Posts: 133 |
Version 2.0.7 is out, I received mine this afternoon here in California, USA. Unfortunately, no release notes attached to it and no apparent layout or UI changes that I can see. Whatever this release fixes must be under the hood. 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround
22nd Dec 2020 12:32am |
110USN Member Since: 13 Nov 2020 Location: Florida Posts: 10 |
Agree updated mine today. USA spec P400 SE
Click image to enlarge 2020 NAS Defender 110 SE, 7-Seat, Pangea w/Black Contrast Roof, Heat/Cool Khaki Windsor Leather, Advanced Off-Road Pk, Black Pk - Deployable Side Steps - Tow Pk (6 Previous Rovers, Stable Mates - '09 135i Coupe, '98 M Roadster) |
22nd Dec 2020 12:42am |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 |
Maybe fixing the low coolant level error saw by TFL...
22nd Dec 2020 5:17am |
Seems that was down to something seem in earlier vehicles many, many times: "The specification is insufficient at ambient temperature for the coolant expansion tank coolant level sensor retainer tabs. Once the coolant expansion tank gets up to a normal operating temperature, the tank retainer tabs are relaxing the force on the sensor. Vibration and shock load from driving is causing the coolant level sensor to drop out of its location and displaying a low coolant level warning, although the expansion tank coolant is at the maximum level." And the official solution is still the same: "Locally source two cable ties with dimensions of 2.5mm x 100mm x 1mm" Click image to enlarge Click image to enlarge |
7th Feb 2021 1:31pm |
