Home > Td5 > Draining a TD5 fuel tank |
davidblythe Member Since: 27 Apr 2019 Location: Cheam, Surrey Posts: 110 |
newby needs help
what is the easiest way to drain a full tank of diesel before i try to remove the tank to replace the pump thank you 1999 90 TD5 CSW 2006 110 TD5 HD Commercial |
3rd Dec 2020 12:43pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17458 |
Siphon it out with a length of hose, it's about the only way.
3rd Dec 2020 1:07pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Agree with Blackwolf, there isnt a very easy way. When I have previously drained about 1/4 of a tank from my 110 I have cleaned off the fuel filter and surrounding area then removed the water drain screw from the base of the filter. With a funnel and fuel can beneath, running the pump purge cycle does allow fuel to be drained at a reasonable pace but wouldnt want to do it for a full tank.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
3rd Dec 2020 1:41pm |
