Home > Maintenance & Modifications > Spafax Mirrors |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
I asked about replacement mirrors as the standard and larger set were very underwhelming.
I was advised on Spafax Mirrors and i took the advice and bought a set. Well made and clamp very tightly with zero movement while travelling at high speeds of 60mph or thereabouts They are about the same size as the original mirrors but are convex so give you a better field of view, but make the rear of the vehicle further away which take a little get used to. I purchased mine from Ebay as it was the best price i could find, links are VM3 Spafax 205mm x 150mm https://www.ebay.co.uk/itm/SPAFAX-VM3-Univ...2749.l2649 You will need 2 of these VM6 KIT's https://www.ebay.co.uk/itm/Adapter-Kit-for...2749.l2649 Message the seller as they'll sort out the postage costs ( i think i paid £17 ) £75 all in for a pair of indestructable solid mirrors. Well worth it |
29th Nov 2020 9:41pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2188 |
Excellent, I'm really pleased with mine
Mo The Land Rover 90 - Many are called, few are chosen. |
29th Nov 2020 10:37pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 760 |
I had a set of heated Spafax mirrors for years but removed them last year and went back to the oversized OE style (which in one form or another I had been using for the previous 15-years).
The Spafax were ok and field of vision wise compared well with OE mirrors but were smaller than the oversize ones I was used to. That wasn't a problem as they still gave a good field of vision but it was the nightime vision that put me off them. At night it could be like looking into an auto dipping rear-view mirror where you get a double image (a ghost image if you like), not a problem 99% of the time but if you wanted a crystal clear image in the dark then you couldn't get it. One place the Spafax did win was by moving the mirror rearwards. I have Climair deflectors fitted and the OE mirrors sit slightly too far forward with the edge being obscured by the deflector, the mounting of the Spafax moved them back a little meaning you got to see 100% of the surface. In the end I removed the Spafax and put them at the back of the shed (just in case I ever decide to give them another go). Just a shame I sold my original mirrors as I had to make up a new set of oversized heads with heating elements! Click image to enlarge ONE LIFE, GET IT! |
30th Nov 2020 6:36pm |
