![]() | Home > Puma (Tdci) > Still waiting for engine |
Following this issue http://www.defender2.net/forum/topic472-75.html Land Rover are going to change my engine. The vehicle is in the dealers and has been since 13th Feb with no sign of the engine turning up. We have a TDV8 FFRR as a loan car, very nice but I want a Defender for work. Even when they change the engine I am still not happy having to get under the car every 2 - 3k miles to tighten the prop bolts. Honestly this vehicle is the worst one I have ever bought.
fingers crossed then AndrewS. 2.4 90 XS
mse Member Since: 06 Apr 2008 Location: UK Posts: 5070 ![]() ![]() ![]() |
I saw 2 new TDCi LR engines on a flat back transit on the M40 on Friday - should have asked i could have pulled him over for you
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
My engine has done 32k without any problems! (yet)
Andew I know how you feel mate, you know the problems I have had with mine. I did not have a new engine and went down I differant route. There is something about those early 2007 models, mine has only done 14k and really is a bag of spanners. I hope when the new engine does arrive it sorts your problems.
solmanic Member Since: 16 Aug 2007 Location: Brisbane Posts: 191 ![]() ![]() ![]() |
My approach is - since I bought a Defender to perform certain duties then any loan car they give me should be expected to perform those duties. The last FL2 they loaned me went back full of dog hair and bits of wood splinters ![]() 1970 Alfa Romeo 1750GTV |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 ![]() ![]() ![]() |
Just use the FFRR for your normal work!! After all they do say they are as capable as a defender.
Telius Member Since: 20 Sep 2008 Location: Roses Posts: 7 ![]() ![]() ![]() |
my engine has 40.000 without problems... only de EGR
Well the engine has turned up, and the replacement process has started BUT .............They have found that the clutch is fooked and guess what the clutch pressure plate is not available
what do you mean it's on back order ? 2.4 90 XS
Sounds like you'll be in the FFRR for sometime then. 2.4 90 XS
Clutch has turned up so the engine is back in the vehicle, however the pulley carrier plate that sits on the front of the engine is on back order.
