Home > Td5 > Should it light up
Tr90
United Kingdom 2000 Defender 90 Td5 CSW Alveston Red
Should it light up
Hi.
I have a td9 90 my2000.
Should the lights on the panel that holds the hazard, rear fog and rear window demister light up when the headlights are turned on?
Post #870157 28th Nov 2020 7:15pm
TVR Tommy
United Kingdom 2000 Defender 90 Td5 Heritage LE Bronze Green
Probably best if you can see the switches in dark.
Post #870165 28th Nov 2020 7:48pm
gcc130
Easies way to find out is to look behind the panel to see if there any bulbs and wiring.
Post #870170 28th Nov 2020 8:02pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Re: Should it light up
The switches should be backlit in greenish white except for the hazard switch triangle which should be orange/red. These are filament lamps so don't last forever but can be replaced when they die.
See https://www.defender2.net/forum/topic16125.html
Post #870171 28th Nov 2020 8:03pm
Tr90
Thanks intercept. Will check it out
Post #870173 28th Nov 2020 8:09pm
Retroanaconda
The OP is referring to the small panel down to the right hand side of the steering column on pre-2002 dashboard.
I don’t think these switches are supposed to be backlit. The hazard switch lights up when in operation.
Post #870177 28th Nov 2020 8:37pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
I had a 300tdi with the similar switch arrangement as early td5s, I dont think they are backlit as said above, I think the only difference was that the heater controls were illuminated on td5s.
Post #870179 28th Nov 2020 8:43pm
Tr90
Ok. Really couldn’t remember when I drove in the dark last time if they were backlit. Thanks for the responses
Post #870180 28th Nov 2020 8:50pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Mine have never lit up unless they were turned on. I ended up converting my switches to back lit by disassembling and reassembling combined switches using old hazard switches.
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #870182 28th Nov 2020 9:00pm
