Home > Maintenance & Modifications > On board air system
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
On board air system
Based on the “wifey system” mine is now up and running on the Defender.
Really simple to do, if you take your time and ensure the connections are tight.
Got fed up with carrying all the extra hoses, pressure gauge, and the time it took to air down, and then air back up 4 tyres.
On the front, my two schrader values are hidden by the A bar, can only be seen from the side, but easy to get to. My tubing routes go from passenger front, to driver front, joins up with a “t” and then down the chassis rail to the wheel arch, “T” off across the centre cross member to the passenger side rear, and “T” off to the driver side rear.
From where they meet before they “T” off, the tubing goes up into the wheel arch, through a grommet and up through the side fill panel for the draw system to meet the control system.
My routing had to go this way because of where I mounted my dual compressor, which I’ll hide behind a panel, waiting on the carpet. I have gullwings, that’s why my control, pressure gauge, release value are installed the way they are.
The rear valves are on brackets, rivnuts, into the rear tub, not a big fan of drilling the chassis.
All I need to do now, zip tie everything down and cover with conduit in exposed areas, but keeping the tubing on the top of the chassis rails, keeps it out of harms ways
Timings.
Air down all four tyres from 38 psi to 20 psi, 48 seconds by pulling up on the release value, blue slider, 2 in from the left
Air up all four tyres, 20 psi to 38 psi 2 mins 08, turn on compressor and turn the value, far left, and watch the pressure gauge.
All four wheels have tubing connected to simple speed lock values, hold, push, locked, wheels have these whips made up, which are stored away under the draw side fill panel. No more pressure gauges, long hoses, or value stem removers.
It’s so simple, it’s brilliant.
Most of the parts he lists in description on the video are available in the U.K. or via Amazon in the states, who ship and add the customs charges, but you can source them, just make sure they are all 1/8” NPT fittings.
I have a bag of values, push fit connectors, enough tubing to a 90 or 110, 4 schrader values, a tube cutter, Teflon tape and two spare rear valve brackets if anyone wants to buy them, £50 all in. All you need to do is source the small air manifold, a pressure gauge, release value slider, and pressure release value.
Everything fits to 8mm push fit connectors and 1/8” NPT fittings.
Post #870091 28th Nov 2020 12:59pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
This is a brilliant idea and well executed Thumbs Up
Am i right in saying it equalizes the system as you deflate/inflate?
Also i would be interested in what you have left, as i will be hard fitting my compressor for the lockers and tyre duties soon Thumbs Up
Post #870144 28th Nov 2020 6:04pm
2010Blackdefender90
Thanks Thumbs Up
Yes, it does equalise the pressures, as he mentions in the video, wait a minute for the pressures after you stop in/deflating.
Tubing, blue, schrader values, 4, all compression fittings, everything to install the tyres to schrader whips x 4
All push connectors and t / y connectors. And two rear schrader mounting plates.
All the gubbings for the control values you will need to get, plus the 18” flexible pipe / hose from the compressor to the manifold. Basically this
Post #870146 28th Nov 2020 6:11pm
2010Blackdefender90
Oh forgot to mention, I have the arb manifold, which supports lockers, unused, if you want that thrown in?
Post #870152 28th Nov 2020 6:46pm
Zed
Very tidy installation. Like that a lot. WARNING.
Post #870159 28th Nov 2020 7:21pm
Badger110
Yes please, i'll PM you to keep the thread clear Very Happy
Post #870162 28th Nov 2020 7:38pm
Lightwater
Australia
A great twin setup you have, the ARB compressors are brilliant.
I wanted a bit more so added a third compressor. The output at the compressor gets seriously hot, adding heat sinks you can still touch the output without burning yourself.
With 3 compressors you get enough air with water for cleaning, or just air by itself there is enough for blowing dust out of the car.
Moisture trap, it is surprising how much moisture there is on a humid day.
3rd compressor in Freelander wheel well & 4L tank (a tank if cool will act a bit like a moisture trap).
2 of my compressors under seat.
Internal & external heat sink also fan cooled.
 Visitor - Freelander owner
Post #870670 1st Dec 2020 5:44am
jst
i use Tmax single and double head compressors on my onboard air installs, seem to do the job well and the original design was made for pumping up more than 1 tyre. the early ARB pumps were for lockers etc and didnt really like pumping up tyres hence the later twin piston etc etc variants. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #870724 1st Dec 2020 11:21am
