Home > Technical > Gear stick thread size (R380?)
Smyles_
Denmark
Hi guys, needing the thread size for both the gear stick and diff lock lever that the knobs screw to on the TD5 (that be the R380?) and curious if anybody knew it off hand or had advice on how to remove them before I go attempt to take them off and potential break stuff Mr. Green
Cheers Stuart
Cummins 130 Build Thread
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #869645 26th Nov 2020 12:47am
ibexman
Thread
M10
Post #869662 26th Nov 2020 8:42am
Smyles_
Denmark
Thank you! Thumbs Up Stuart
Instagram
Post #869728 26th Nov 2020 3:46pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Ye, thanks, I've always wanted to know just in case.
Post #869778 26th Nov 2020 7:09pm
jfh
Sorry. Double post.
Post #869779 26th Nov 2020 7:09pm
Oldowner
Re: Thread
ibexman wrote:
M10
The R380 is M12!
Post #870076 28th Nov 2020 9:56am
jfh
Thanks
Post #870077 28th Nov 2020 9:59am
Smyles_
Denmark
So I went out and bought some more nuts since I no longer have access to any of my stuff back home and the diff lock knob has an M10 thread whilst I'm certain the gear knob is an M13 thread. I say that as only purchased up to M12 nuts and I could not get it to thread on the stick, but I'll go and buy some more tomorrow evening to make sure.
Thanks though guys! Thumbs Up Stuart
Instagram
Post #870372 30th Nov 2020 12:57am
It won't be M13 because there is no standard for a 13mm thread in the ISO Coarse Series standard. So M12 or M14 are your options.
If it really isn't an M12 x 1.75mm pitch ISO Coarse Series thread, it could be a metric fine series thread (unlikely) or it could be 1/2" UNC or UNF.
Series 1 and 2 gear knobs were 1/2" BSF.
I've found a reference to the LT77 being 1/2" x 20tpi, which can only be a UNF thread.
I can't find the definitive answer for the R380 and unfortunately don't have one with a screw-on knob to measure.
Post #870448 30th Nov 2020 10:46am
Smyles_
Denmark
Ah, yes... the elusive M13, what am I talking about?!? Thank god I didn't go to Uni for 5 years to get a masters in civil engineering... Whistle I need to learn to go to bed earlier!
There's no way its an M12, the nut wouldn't even catch the thread. I even removed some of the paint and guff off that's collected over the years to make sure.
Just wish I had my tools to measure this stuff instead of buying even more hardware that I already have back home! Banging Head Stuart
Instagram
Post #870468 30th Nov 2020 12:34pm
I think you are probably going to win with 1/2" UNF.
Post #870473 30th Nov 2020 12:48pm
dorsetsmith
1/2" UNC Whistle
Post #870486 30th Nov 2020 1:36pm
1/2" UNC is a very coarse thread at 13 tpi (coarser, marginally, than M12), whereas UNF is 20 tpi. I'd be a little surprised at 13 tpi on a gear lever knob, but you never know.
Is a Disco2 the same as a Defender? If so, I could whip my knob off and find out for sure.
Post #870504 30th Nov 2020 2:57pm
Smyles_
Denmark
It looks to me to be UNF. That and the fact it takes lots of unscrewing to undo! Stuart
Instagram
Post #870513 30th Nov 2020 3:36pm
Smyles_
Denmark
Just for future reference if anyone comes looking here, the thread for the gearstick knob was in fact 1/2" UNF with the thread for the diff knob being M10.
Thanks guys Thumbs Up I'll make a post later on why I needed these. Stuart
Instagram
Post #872481 11th Dec 2020 6:54pm
