![]() | Home > For Sale & Wanted > [For Sale] Red booster clutch assembly |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2939 ![]() ![]() |
As I am going auto I won’t be needing this.
£250 posted for the full assembly. ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 545 ![]() ![]() |
Which engine and year is it for?
Came off my Dec 2014 110. Andy
mynamesbuck Member Since: 26 Apr 2019 Location: Midlands Posts: 23 ![]() ![]() ![]() |
Excellent bit of kit if I wasn’t selling mine now I’d have been very keen! GLWS
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
I’m interested as my knees are shot, is it a fit and forget item other than levels being topped up?
How much difference does it make? Cheers |
Smyles_ Member Since: 26 Aug 2018 Location: Copenhagen Posts: 519 ![]() ![]() |
I have a TD5 redbooster in my truck and would absolutely recommend one. Mine was fitted by the previous owner who if I remember correct was neighbours with UKs rep in Edinburgh. You can even see my trucks former glory on the redbooster front page.
I've only ever had to fettle with it once, only because the garage who replaced my clutch and dmf royally messed about with it! I measured the pedal force against my mum's Freelander a while back (can't remember the numbers) and was considerably lighter. If I were to ever buy another Defender, one of the first things I'd do is install another redbooster ![]() ![]() Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
I did a write up when mine got fitted. If you search for redbooster and my user name in the appropriate section you will find it complete with pics. I’ve had 0 problems with mine and if I hadn’t had it fitted then I would have had my motor up for sale last year when I had a very large bakers cyst inside my left knee. I totally recommend it to anyone especially if you’re having any problems with your left leg. Yes the expansion tank moves slightly and a vacuum reservoir is fitted under the offside wing top but as you will see from the pics it looks factory. PS, no levels to be topped up, the servo is vacuum ‘powered’.
benspray Member Since: 31 Jul 2014 Location: Norfolk Posts: 165 ![]() ![]() ![]() |
Are we saying this definitely wont fit a TD5? or just that it needs more work/parts to make it fit?
Thought I was ok with the clutch as I'd just been doing short journeys, I spent a couple of hours with it the other day and I need to do something to make it lighter either one of these or a LOF spring perhaps.... Cheers all |
Changed my standard overcentre spring for a LOF one, I did not feel any difference, but maybe thats me. Still bloody heavy, wife does not lie reversing trailer with clutch as it is.
Sorry guys but this sold yesterday to Def90 on here and I haven’t been online to update. Thanks for the interest Andy
