Home > Puma (Tdci) > For our friends in the nordic countries and russia
Eduardo
Puma Engine Breather Pipe Freezing
Models:
Defender (LD)
2.4 Diesel Puma Only VIN-range: 7A732615 Onwards
Markets: Russia and Scandinavian Markets Only
Section: 303-00
Summary:
Engine oil leaks.
Cause: Driving the vehicle at temperatures on or below Zero deg C, freezing of the engine crankcase breather hoses resulting in engine oil leaks. Suggested Customer Concern Code - D50.
Action: Should a customer express concern, install a new heated breather kit. Follow the Service Instruction outlined below.
Cheers! Eduardo
Post #8697 21st Mar 2009 2:22am
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
Re: For our friends in the nordic countries and russia
Models:
Defender (LD)
Section: 303-00
Summary:
Engine oil leaks.
Cheers!
Thanks
Post #8698 21st Mar 2009 4:24am
Glynparry25
I don't live in Russia, or scandinavia but spend as much time as I can in the Alps where the temp regulary goes bellow zero- what would be te deal if I get this problem?
Glyn
Post #8705 21st Mar 2009 9:45am
Grockle
Glyn,I would contact your dealer tell them of this issue making them aware you travel abroad alot in similar temperatures. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #8707 21st Mar 2009 10:19am
mse
I want to know what the heated breather looks like Mike
Post #8711 21st Mar 2009 10:56am
Eduardo
Hi there
There is some pictures in the report.
When I had a little bit more time I will put the entire bulletin in the net.
Cheers Eduardo
Post #8719 21st Mar 2009 12:32pm
