Home > Maintenance & Modifications > Labcraft Scenelight Si9 - any good?
Matt110
They seem good value. Anyone had or have one or two and can report how they find them?
How has the coating lasted and how are they for using both as reversing lamps and also as camp site illumination?
It looks like they can be mounted either vertically or horizontally upside down and still achieve a 45 degree angle due to the angle of the base to the lamp?
Post #869630 25th Nov 2020 9:39pm
backpacksandroofracks
United Kingdom 2006 Defender 130 Td5 HCPU Alveston Red
Hi Matt, I've one Labcraft Si9 mounted on the side of the rear canopy of my 130. I use it as a 'camp' area light for chilling under after the suns gone down. It's a really nice light, bright but diffused so quite soft and easy to work/cook/prep/chill under. Quality is great, rubber gasket is good, I placed a bead of bond between truck and gasket and then between gasket and light for ultimate waterproofing, no issues so far.
I have two Lazer Utility 25s used for reverse lamps but would think that Si9 would work more than well enough, provides more light than I was expecting and a decent throw for the size of the unit.
Cheers, Joe.
Post #872272 10th Dec 2020 12:40pm
Jem_90
United Kingdom 2011 Defender 110 Puma 2.4 USW Baltic Blue
I can recommend this Rigid scene light.
It is very bright and has a great flood pattern.
https://www.rigidindustriesshop.co.uk/prod...1994922033
Post #872421 11th Dec 2020 2:14pm
jimbo55
Matt, I have not personally got the lab craft, but a few mates have had them and they are very good
I have the rigid that Jem has, however I wouldn’t recommend it. The light output isn’t great, it’s “ok” but for the money the labcraft is a much better option
Post #872423 11th Dec 2020 2:26pm
Mo Murphy
I have 2 si8 lamps on my 90 for camping, not the same model but they are superb for campsite lighting, bright illumination but not blinding.
A bit tricky to photograph but a couple below.
HTH
Mo
 The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey
Post #872472 11th Dec 2020 6:31pm
