- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
robrennie
Exmoor Trim Heated Seats Installation | |
Hi All,
I have a new to me 2007 Tdci - which I am thrilled with. I have some Exmoor Trim seats that need the heating wiring in.
I have Exmoor trim wiring loom and some Tdci heated seat switches with some wire connected.
My vehicle started off as a truck cab, the fuse box has a fuse for heated rear windscreen - so this is where I run out of knowledge
Can I simply take the fuse box that is below the steering column off and take a live off that fuse position? Take it to the single power into the Exmoor Loom - then connect the wires that go to the Exmoor trim switches to the new Defender switches.
I think then I need to attach a backlight live to the switches are well? - which I think the an orange wire, but pretty easy to work out.
Thanks
Rob.
25th Nov 2020 7:06pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
